View unanswered posts | View active topics It is currently 14 May 2026, 11:22
Bassman clon med master.
Post Bassman clon med master.
Pignose G40V.
Numera svart och läderhandtag, stiligt värre.
Den har en Weber California alnico i sig!
Nya rör och allt.
Kan skickas om du betalar.
Kan levereras om du befinner dig någonstans mellan Göteborg och Laholm.
Kostar ynkliga 2000kr.
https://www.youtube.com/watch?v=GeJFvRFUSsw
The new Pignose G40V is a technical marvel that puts out a screaming conservatively rated 40 watts RMS through its own specially designed 10 in. speaker.
A truly pro amplifier, this little (14 x 9 x 17 in.) powerhouse features 2 - 6L6s, and 3 - 12AX7 tubes, 4 and 8 ohm output jacks, controls for volume, master volume, treble, mid, bass, and presence.
It's perfect for the bedroom, but really shines when you "open it up." It is capable of powering a 4 x 12 in. cabinet!
Pignose commissioned the world-renouned tube amp engineer and designer Dennis Kager to perfect this little monster, and it has been Field tested in clubs for 6 months to great acclaim.
The G40V is built like the time tested tube amps of the 60's, but in a tiny package, like a stealth amp. They'll laugh when you walk in with it, but they'll become true believers when they hear it crank. Best of all, it has the classic Pignose look and solid reputation
The Pignose G40V is compact, pro quality, powerful, The ultimate combination!
11 Jun 2015, 12:08
Post Re: Bassman clon med master.
Vemodigt såld.
12 Jun 2015, 21:35
