http://www.ljudbojen.com/
Bassman clon med master. HEAD. SÅLD.
http://www.ljudbojen.com/viewtopic.php?f=25&t=103317
Author:  T-Toby [ 25 Jun 2015, 11:51 ]
Post subject:  Bassman clon med master. HEAD. SÅLD.
Alltså en Bassman clon med master.
Pignose G40V.
Endast som topp, så hoppa högtalarbeskrivningen i texten nedan.
Cabinett av plywood, klädd med zebratyg, snygg och rockig.
Kan skickas om du betalar frakten.
Kan levereras mellan Göteborg och Laholm.
Futtiga 1500kr. (Ungefär vad du kommer att bränna av din färska lön, och vingla hem ensam ikväll eller senast imorgonkväll...)
https://www.youtube.com/watch?v=GeJFvRFUSsw
The new Pignose G40V is a technical marvel that puts out a screaming conservatively rated 40 watts RMS through its own specially designed 10 in. speaker.
A truly pro amplifier, this little (14 x 9 x 17 in.) powerhouse features 2 - 6L6s, and 3 - 12AX7 tubes, 4 and 8 ohm output jacks, controls for volume, master volume, treble, mid, bass, and presence.
It's perfect for the bedroom, but really shines when you "open it up." It is capable of powering a 4 x 12 in. cabinet!
Pignose commissioned the world-renouned tube amp engineer and designer Dennis Kager to perfect this little monster, and it has been Field tested in clubs for 6 months to great acclaim.
The G40V is built like the time tested tube amps of the 60's, but in a tiny package, like a stealth amp. They'll laugh when you walk in with it, but they'll become true believers when they hear it crank. Best of all, it has the classic Pignose look and solid reputation
Author:  isak [ 25 Jun 2015, 16:26 ]
Post subject:  Re: Bassman clon med master. HEAD.
Är ev intresserad, bor i gbg. Är det en topp original? Hur bred?
Author:  T-Toby [ 25 Jun 2015, 16:35 ]
Nej, inbyggd i nytt tjusigt cabinett.
Existerar inte som original head.
Finns tillgänglig i Masthugget ikväll och kanske på dagen imorgon, i helgen i Laholm.
Bredd: 34cm.
Höjd: 22cm.
Djup:22cm.
Author:  T-Toby [ 25 Jun 2015, 22:26 ]
Wöööu! Jag kunde lägga till en bild på toppen!
Kom visst med en bild på en gammal GMF-kändis också...
Author:  Sir Realistic [ 26 Jun 2015, 08:14 ]
....och Sharkfin-plektrum, de ser man inte så ofta numera.
Jag är intresserad av toppen men jag finns i Stockholm så där kanske logistiken spricker.
Author:  T-Toby [ 26 Jun 2015, 10:42 ]
Sharkfin inhandlat hos BEME i Helsingborg dessutom.
BEME var ju lite GMfkult han också...
Det finns en stark, riktigt stark GMFkoppling till på bilden...den som finner får rabatt :mrgreen:
Stockholm?
Logistiska problem?
Nä, Jag kan skicka.
Har en vän som ska till Blecktornsstigen, Söder nästa helg, fjäskar jag kan det funka att få med den i packningen.
Author:  Sir Realistic [ 26 Jun 2015, 18:30 ]
Stockholm?
Logistiska problem?
Nä, Jag kan skicka.
Södermalm nästa helg, woohoo - det vore ju perfekt, jag bor bara ett par hundra meter från Bleckan.
Author:  T-Toby [ 26 Jun 2015, 19:45 ]
Fan, jag känner mig som en riktig fixare idag, gratisfrakten till "Bleckan" är nämligen fixad.
Jag PMar dig.
Author:  Sir Realistic [ 27 Jun 2015, 11:44 ]
PM tebax :D
Author:  Sir Realistic [ 27 Jun 2015, 12:27 ]
PM tebax :D
Pengarna ska finnas på ditt konto nu 8)
Author:  T-Toby [ 27 Jun 2015, 21:10 ]
PM tebax :D
Perfa!
Pm om vem leverantörent är och var han bor.
Author:  Sir Realistic [ 06 Jul 2015, 23:25 ]
Post subject:  Re: Bassman clon med master. HEAD. SÅLD.
Nu är stärkaren under mina bedkyddande vingar.
Lät den glöda i replokalen idag och den där blir jättebra för mig tror jag.
På onsdag ska jag testa den med bandet.
Tack för en smidig affär och bra transport/leverans. 8)
Author:  T-Toby [ 07 Jul 2015, 10:26 ]
Alltid trevligt med nöjda kunder!
Author:  Sir Realistic [ 09 Jul 2015, 08:12 ]
OK, nu sista (?) inlägget i denna tråd från mig.
Fungerade klockrent i ljudbilden tillsammans med övriga instrument i bandet.
Spelade den genom en 1x12, en Celestion av något slag i en sluten låda.
Nu blir det nog att sälja av lite utrustning,
har samlat på mig en del under jakten på "det perfekta ljudet" 8)
