View unanswered posts | View active topics It is currently 01 Nov 2026, 03:46
Morgan AC40 Deluxe
Post Morgan AC40 Deluxe
Specar:
• Three modes Normal/Brilliant/EF86
• Hand-wired in the USA
• 4x EL-84 power tubes
• 2x 12AX7 preamp tubes
• 1x EF86
• Power Level control
• Global Cut removes high frequencies from the power section
• Volume
• Bright switch
• Bass Cut Switch
• Switchable EF86/12AX7
• 2x8 ohm 1x16 ohm outputs
• Custom USA made Mercury Magnetics transformers
• Celestion Alnico Gold Speaker.
https://youtu.be/LSXLs9V8BUM
OBS! Inga byten. Prutat och klart.
Kan skickas om mottagaren betalar frakt.
Pris: 14000 kronor
31 Jul 2017, 12:32
