| Morgan AC40 Deluxe http://www.ljudbojen.com/viewtopic.php?f=25&t=115996 |
Page 1 of 1 |
| Author: | uhogberg [ 31 Jul 2017, 12:32 ] |
| Post subject: | Morgan AC40 Deluxe |
Specar: • Three modes Normal/Brilliant/EF86 • Hand-wired in the USA • 4x EL-84 power tubes • 2x 12AX7 preamp tubes • 1x EF86 • Power Level control • Global Cut removes high frequencies from the power section • Volume • Bright switch • Bass Cut Switch • Switchable EF86/12AX7 • 2x8 ohm 1x16 ohm outputs • Custom USA made Mercury Magnetics transformers • Celestion Alnico Gold Speaker. https://youtu.be/LSXLs9V8BUM OBS! Inga byten. Prutat och klart. Kan skickas om mottagaren betalar frakt. Pris: 14000 kronor |
