View unanswered posts | View active topics It is currently 17 Oct 2026, 22:57
Victory Amps 1x12 Cream Back
Post Victory Amps 1x12 Cream Back
Hej säljer en super fin victory 1x12 med Creamback helt I nyskick då jag gått över till combo stärkare.
Lånade bilder tills jag är hemma.
Power handling: 65 watts
Impedance: 16-ohms
Speakers: 1 x Celestion G12M-65 Creamback
Size (mm): 480(w) x 480(h) x 292(d) (from December 2018)
Weight: 35.49lbs/16.1kg
SPEAKER CHARACTERISTICS: The G12M-65 Creamback is less sensitive/efficient (97dB) than the Vintage 30 and also the H-75 Creamback, using a medium-magnet (35 ounce) 12-inch driver. Celestion regard it as a 'more powerful Greenback' and that is the perfect description. Expect that classic, 'woody' tone and feel to add colour to your medium gain sounds, with a little speaker breakup to boot… albeit with a full 65 watts power handling which is 40 more than the standard Greenback. Compared with the 75-watt Creamback, the 65 is less sensitive/efficient so sounds less loud at equivalent amp volume settings. It has more colour to the tone overall, a looser bottom end and breaks up earlier.
We recommend it for anyone who likes classic low/medium gain tones at low/medium volume; or who likes plenty of speaker 'give' and colour at higher volumes. We think it works perfectly with the V40's unique dynamic and feel.
21 Feb 2021, 11:00
Post Re: Victory Amps 1x12 Cream Back
Tjenare!
Är lådan sluten eller öppen? Pris?
Finns var?
04 Mar 2021, 18:15
