View unanswered posts | View active topics It is currently 24 Jun 2026, 10:09
Celestion 12" Hellatone G12H-SÅLD
Post Celestion 12" Hellatone G12H-SÅLD
30W/8Ohm
Broken in/inspelad och lite extra moja enl deras specifikationer.
"HELLATONE 30 We start with a stock great sounding classic G12H30 Celestion. We convert it into a Hellatone by aging it slightly and by exercising the suspension for 15 hours so when you get it, it has a warmer tone on the very first note. This process gives the Hellatone 30 an even richer low end than it already had. The model 30 has wonderful mids and highs and a beautiful overdrive tone. If you drive it hard , you get a real nice cone break up that sounds fantastic. Large Heavy 50 oz magnet 30 watts.8 ohm or 16 ohm For specs, go to http://www.celestion.com classic G12H30 (70th year Anniversary.. not Heritage)
Kan 700:- inklusive frakt vara ngt?
04 Nov 2010, 00:31
rudmark wrote:
30W/8Ohm
Kan 600:- inklusive frakt vara ngt?
Så det kan bli... 600 inkl frakt
04 Nov 2010, 00:32
Hmm den där är jag sugen på..
Du behöver ingenting i byte? Typ ett set gfs dream/mean 90?
Hård rock n roll:
http://www.myspace.com/ironlambofficial
Slafsig death metal:
http://www.myspace.com/generalsurgery
Officiell Fender-artist
http://www.fender.com/artists/artist.php?id=432
04 Nov 2010, 09:57
Nja inga byten f.n. tack. Men viss prisdumping kan ges
04 Nov 2010, 17:32
