Kendrick So-lo 7.
En fantastisk förstärkare som är otroligt välljudande både i hemmiljö och på scen. Denna modell har inbyggt power attenuator och optionen med ett extra slutrör vilket ger den 14 watt. Ingen biasing behövs, bara att stoppa i röret om man vill ha mer kräm.
Helt rördriven med reverb och hörlursutgång som tystar högtalaren.
Specialbeställd från USA med 230V-trafo.
Kostade mig ca 19 700:- innan jag hade stärkaren hemma. Ca 1,5 år gammal. Älskar den men ekonomin är inte den bästa just nu.
Släpper den för 12 000:-
Läs mer på Kendricks hemsida:
http://www.kendrick-amplifiers.com/mm5/ ... _Code=0104Voiced to sound exactly like a Blackface Super Reverb amp but at a fraction of the volume and about a 1/3 of the weight, we have carried this to a new level by adding a "Texas Tea" control which can layer a Tweed tone on top of the default blackface voicing. Add just a little "Texas Tea" and you get that two-amp, Stevie Ray tone. Turn it all the way down and you have pure blackface tone. Turn it up and the tweed voice overshadows the blackface voice and you have pure tweed tone.
For tonal variations on a theme, there is a three-way slider switch that goes between a stock voicing; a more compressed jazz voicing (slightly less gain with more compression) and a more cutting lead voicing (think British).
Transformer driven, Tube/spring Hammond-style reverb is standard. This is the same circuit used on all blackface Reverb amps and includes an on/off footswitch.
The on-board power attenuator can be used when 7 watts is too loud. It will go from the full 7 watts all the way down to "off".
A headphone output jack automatically disconnects the 12" Kendrick Greenframe speaker so that you can rehearse privately, without anyone else hearing it. You can actually use the built-in power attenuator as a headphone volume control, thus allowing you to turn the amp up and the headphones down.
Kostade mig ca 19 000:- innan jag hade stärkaren hemma. Ca 1,5 år gammal. Älskar den men ekonomin är inte den bästa just nu.
