View unanswered posts | View active topics It is currently 24 Sep 2026, 05:12
Marshall 30th anniversary 6100LM
Post Marshall 30th anniversary 6100LM
5900:-
Finns i Stockholm.
The 6100LM was made in 1995. It has three channels: Clean, Overdrive, Lead. The clean channel reproduces a JTM45 circuit. The overdrive channel, however, has three modes which work like the newer JVM models from Marshall. The first one is a reproduction of a JTM45 on slight breakup, the second is a 1959 plexi and the third one is a JCM900. The lead channel is a boosted JCM900. The footswitch allows to go from one channel to the other, and that's it, pretty straightforward. The amp also has a plethora of other features: two effects loops (parallel or series), 8 or 16 ohm speaker outputs, separate channel EQs, midi switching, and it can be used with half its power, bringing it down to 50 watts.
Köparen betalae ev. frakt.
06 May 2013, 19:00
