View unanswered posts | View active topics It is currently 19 Apr 2024, 21:12
Highorder Maximus Humbucker SÅLD
Post Highorder Maximus Humbucker SÅLD
Handlindat från USA, rätt så het men ändå PAF-karaktär, hemsida:
http://www.highorderpickups.com/
9,5K, kabel utan förlängning (pålödda kablar av mig) 15 cm, med förlängning 20 cm.
9.4-9.7k "Maximus" Wind - Provides enough drive for a slightly more "gainy" sound, but retains a lot of the articulation and definition of a lower output pickup. Allows pairing with higher output at the neck. As with any HighOrder pickup, the actual DC resistance varies with the magnet wire lot on hand. Bigger builders have more control over this. I wind to turns though so the tone of the pickup remains intact while the dc resistance varies within a certain range. These are built with AlNiCo 5 only!
500:- inkl frakt
06 Sep 2017, 13:59
