View unanswered posts | View active topics It is currently 02 Nov 2026, 03:46
Reply to topic  [ 9 posts ]
Analog Man Astro Tone Fuzz = SÅLD =
Post Analog Man Astro Tone Fuzz = SÅLD =
<font size="2"><b>SÅLD</b></font id="size2">
Helt ny fuzzpedal i Fuzz Face-skolan.
Slö som jag är klipper jag in lite info om den från Analog Mikes hemsida. [8D]
Many people have problems using a Fuzz Face type pedal, like our Sunface, live with a band. I had the same problem which is one reason we are making these pedals, it’s something I need to get the sounds I want. I play Fender amps with a Les Paul, which is not too favorable to fuzz face pedals. But this pedal works great with that setup.
The sound is not as compressed as a Fuzz Face, not SUPER thick and saturated, something between a fuzz and distortion. It’s fuzzier into a smaller amp (Fender Deluxe), and more of a BOOSTER into a large distorted amp (Marshall 1970s Super Lead). It can also be stacked with other pedals, for example running a fuzz face into it can get a sound like Spirit in the Sky, which buzzes and cuts out. Or run the Astro Tone into an OD pedal like a TS808 or KoT to make it fatter.
Features:
1. True Bypass switching
2. Super Bright LED for lower power use, buffed so as not to blind you!
3. Uses less than 1 mA of power when off, only 3 when on, so an Alkaline bat tery will last a few hundred hours of normal playing time.
4. Normal Boss style power jack, negative ground so no polarity problems
5. Three simple knobs - Volume, Fuzz, and Tone.
6. High quality, hand wired RE’AN input and output jacks.
7. original 1966 Fairchild Silicon transistors, not affected by heat like a Germanium fuzz.
8. Sound is not as compressed as a fuzzface, not SUPER thick and saturated, something between a fuzz and distortion but closer to a fuzz.
Kom med vettiga bud, eller fresta mig med ett bra byte.
31 May 2010, 22:45
mAiL!
01 Jun 2010, 01:14
Och mail till Hyper Pak...
01 Jun 2010, 09:35
mAiL tebax
01 Jun 2010, 20:32
Kan jag locka med en RC-Booster?
Instant-02 (Konjuk)
01 Jun 2010, 20:50
Instant-02 (Konjuk)
Sorry, den är så nära såld den kan vara...[:)]
01 Jun 2010, 21:23
OK. Får man fråga var man kan hitta en sån däringarn pedal? [:)] Måste man ta från staterna?
Instant-02 (Konjuk)
02 Jun 2010, 08:47
Instant-02 (Konjuk)
Det går jättebra att fråga...[:)]
Jag köpte den direkt från tillverkaren. Jag har sett att Thesegoto11 har den upplagd på sin hemsida, men det verkar som att de inte fått hem den ännu.
02 Jun 2010, 09:15
analogman.com är billigt
_______________________________
Har en massa Lavakablar:
Pedalbordskit, krullkabel, clear connect - maila mig !
02 Jun 2010, 14:55
