View unanswered posts | View active topics It is currently 06 Nov 2026, 21:15
HAO Rumble mod, Fullton DP
Post HAO Rumble mod, Fullton DP
The Rumble MOD is Hao's ultimate overdrive pedal. This overdrive/booster pedal uses hand-selected components to provide the purest, smoothest, thickest overdrive ever. The problem with most OD pedals lies in mismatched input/output impedances that can make components work overtime. The Rumble stompbox's input and output buffers provide proper impedance matching, allowing its circuitry to focus purely on generating the fattest overdrive possible.
Pris 1400-, SEK + frakt
Fulltone Distortion Pro
Not a FUZZ! Designed to make a Tele, Strat, or other single coil-equipped guitar compete with a Les Paul, although many humbucker-users love it too. The DP-1 has great hi-gain sounds that are FAT and juicy. The "Saturation" knob allows you to soften or sharpen the attack of the notes and to firm the bottom-end. If you have a single-channel amp with a great clean tone then this is the pedal to get to add Marshall-like Lead tones without having to re-adjust the settings on your amp.
Pris 1100-, SEK + frakt
27 Jul 2010, 17:10
Byta rumble mot fulldrive 2 mosfet?
27 Jul 2010, 20:18
nei takk [:)]
28 Jul 2010, 17:29
