View unanswered posts | View active topics It is currently 26 Oct 2026, 00:58
Logelloop Great Software looper for mac
Post Logelloop Great Software looper for mac
I did some beta testing and I highly recommend this Looper very intuitive and with many nice features.
http://logelloop.logellou.com/en/Home.html
Quote:
With Logelloop you can :
1.
• Make multitrack mono or stereo audio loops
2.
• Change speed of each track separately
3.
• Use time stretch or pitch shift
4.
• Spatialize directly to up to 9 speakers
5.
• Make your own Macros
6.
• Mix directly inside the looper with your VST plugs.
7.
• Use a Granular synthesis arpeggiator
8.
• Use Delays synced to your audio loops
9.
• Use Convolution between loops
10.
• Use Ring modulation between loops
11.
• Copy your loops on the Hard drive
12.
• Insert your patches made with Max/MSP
13.
• Etc
Bapman
swimming with a hole in my body
"The only thing worse than a guitar is a guitarist!"
- Lydia Lunch
28 Aug 2010, 15:01
