NPN general purpose transistor 2N5088
FEATURES
· Low current (max. 100 mA)
· Low voltage (max. 30 V).
APPLICATIONS
· Low noise stages in audio equipment.
DESCRIPTION
NPN transistor in a TO-92; SOT54 plastic package.
PIN DESCRIPTION
1 collector
2 base
3 emitter
Fig.1 Simplified outline (TO-92; SOT54)
and symbol.
SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT
VCBO collector-base voltage open emitter - 35 V
VCEO collector-emitter voltage open base - 30 V
ICM peak collector current - 200 mA
Ptot total power dissipation Tamb £ 25 °C - 500 mW
hFE DC current gain IC = 1 mA; VCE = 5 V 350 -
fT transition frequency IC = 500 mA; VCE = 5 V; f = 100 MHz 50 - MHz
F noise figure IC = 200 mA; VCE = 5 V; RS = 2 kW;
f = 10 Hz to 15.7 kHz
- 3 dB
självklart kan ELFA ersätta en sån- förmodligen Bejoken med
tec BC549B
https://www1.elfa.se/data1/wwwroot/asse ... 50C_en.pdfb
