View unanswered posts | View active topics It is currently 29 Oct 2026, 23:16
Xinsound Sustain-fuzz Overdrive
Post Xinsound Sustain-fuzz Overdrive
Hej. Fick hem denna pedal idag och den kan jag rekommendera. Vilket gött sound.
XinSound DF-20 is a Distortion/Fuzz/Sustainer pedal, its have three controls that let you dial in the finest harmonic distortion/sustain ever produced. Puts this distortion/sustainer in a more compact and rugged die-cast box, but the sound is true to the 1970 original--silky smooth violin-like sustain that lets you hold a note for an entire set. Level, Tone and Sustain controls that let the player dial in the finest harmonic distortion/sustain ever produced.
Specifications
* Controls: Level, Tone, Sustain, Toggle switch & True Bypass.
* Classic 100% Analog circuits
* Housed in a compact, die-cast box
* True Bypass design, On/Off LED status indicator
* Runs on 9 V battery or the 9V DC power supply
* Connectors: Input, Output, AC Adaptor
* Dimensions: 4.5” (L) x 2.5” (W) x 1.5” (H)
* Carton Size: 420 x 328 x 163 mm and 24pcs/Carton
13 Jun 2014, 21:54
