View unanswered posts | View active topics It is currently 29 Oct 2026, 18:52
Kan man köra T-Rex Tremster & Reptile på 12v?
Post Kan man köra T-Rex Tremster & Reptile på 12v?
Har för mig att jag har läst det någonstans, stämmer det?
I manualen står det: Maximum Power Supply Voltage 12,5v. det måste väl betyda att det är OK, eller hur?
11 Mar 2011, 01:27
Det brukar betyda att det är ok att köra upp till 12,5v
11 Mar 2011, 08:36
Tremolo brukar låta bättre om man ökar drivspänningen, så testa, står det att den tål 12,5 tål den sannolikt mer än det.
11 Mar 2011, 09:01
Tack för svar, hittade också informationen på T-Rex hemsida:
1. What voltage does your pedal accept to be driven?
You need to find this information in the pedal users manual or on the pedal. Most pedals today accept 9 or 12 volt. Some need 18 volt. If there is a battery container in the pedal it usualy just needs 9 volt, but often it also accepts 12 volt.
All T-Rex pedals can run on 12 volt. Some (the ones with battery container) can also run on 9 volt. But they accept any voltage between 9 and 12 volt.
If your pedal get's less than the voltage it needs, there is no danger. It will not break or burn. It just sounds different or says nothing at all. Some musicians even use old batteries, that gives less power and therefore the pedal gives another sound - which they like.
If your pedal get's more voltage than it needs, there is danger that the pedal will break or even burn. If you are lucky, it will have a fuse inside (to be replaced), but most pedals don't.
11 Mar 2011, 10:47
