Hej, ska byta ut elektronik i en 335 kinakopia. Någon som provat detta? Motstånd 220k+kond 471pf parallellt med volympot (se nedan). Kinesen skrapar och glappar, så om man ändå mekar....
Jag byter säkert inte elektroniken varje vecka precis.
/Roger
från Mojotone.com:
Volume Mod(Stock on most prewired assemblies): Jump a 220k resistor and a
471pf capacitor parallel from the un grounded outer lug (the same lugs that the
pickup leads go to) to the center lug on each volume pot. This will give you a
smooth taper and preserve your highs when you turn down. This also helps bring your pickups to life a little.
