View unanswered posts | View active topics It is currently 02 Nov 2026, 07:07
Brown Rabbit LM308-OD - såld
Post Brown Rabbit LM308-OD - såld
Freakshow effects Brown Rabbit.
Utbyggd boutique-variant av ProCo Rat, Jeff Tweedys favorit-OD.
Ger allt från clean boost till krämig eller taggig dist via tre-lägesswitch.
Pris: 800 kr i grön postpåse.
Saxar från tillverkaren:
The 3-way select switch
"In between the volume and drive knobs is a little selector switch.
This switch is used to select between different drive options the Rabbit may be equipped with.
From here on it gets technical...use caution!!!!
In the left position (1) the pedal is using a NOS LM308 op-amp and an asymetrical diode clipping section.
This diode configuration is one of what many of the latest wave of "boutique" overdrive pedals are using
to get their sound. In the center position the pedal is configured to use the NOS LM308 op-amp ONLY!
There are no diodes being used here. Notice the difference in volume? We call this the "boost" mode,
it will take you from boosted semi-warm tones to a light, loud, overdrive.
In the right position you have activated the L.E.D. clipping section of the pedal.
In this position you are using the NOS LM 308 op-amp as well as the 2 L.E.D.'s that you can see on the
top right of your pedal. Notice that they will light up and flicker as you play!
The more drive you have dialed in combined with how hard you are playing will determine
how bright they get. It is common for one of the LED’s to glow dimly even when you are not playing
the pedal while in this mode…don’t worry! It’s not gonna explode on ya!
This mode gives you a nice thick fat distortion sound. Now that you understand the basics of the Rabbit
controls go on and play around with it for a few hours....find what tone YOU like best!"
Lasse
07 Aug 2012, 22:34
Post Re: Brown Rabbit LM308-OD
Nu fick du PM.
Har kollat efter en äldre Rat, men den här lär väl funk minst lika bra...
07 Aug 2012, 22:48
pDahl wrote:
Nu fick du PM.
Det lär den - låter riktigt bra.
On hold till dig.
Lasse
07 Aug 2012, 23:03
