Joespinaci
 Reverend charger290
Jättefin Reverend Charger 290 I nyskick, säljes för att den har för tunn hals för min smak.
Nypris 9.800:- Mittpris 8.000:-
Spec: KORINA BODY Korina (aka White Limba) is a medium-light weight wood, highly prized for consistency and tonal qualities. Often found in boutique and vintage instruments, all Reverends feature Korina bodies. A highly resonant wood, Korina is a key factor to producing these lively, responsive instruments that are rich in harmonics.
BASS CONTOUR This passive bass roll-off is great for tightening up the low end, or re-voicing the pickups. It can make a humbucker sound like a single-coil, or give a P-90 that classic twang. Variable pickup voicing at your fingertips
PIN-LOCK TUNERS A thumbwheel under the tuner pushes a steel pin up through the post, locking the string in place for exceptional tuning stability and super-fast string changes. Also, the posts are custom height, eliminating the need for a second string tree.
DUAL-ACTION TRUSS ROD These dual action rod adjusts in both directions, allowing back bow or forward bow. This assures correct adjustment range is possible regardless of string tension, extreme climate conditions, or the effects of long term aging. It’s also located at the headstock for easy access.
GRAPHITE NUT There's a graphite impregnated nut on all Reverend instruments. Graphite reduces friction, allowing the strings to easily slide through the nut slots, improving tuning stability.
SPECIFICATIONS: BODY korina solidbody. NECK PROFILE medium oval. NUT 1-11/16" (43mm) width, graphite. PICKUPS CP90 bridge, CP90 neck. FINGERBOARD Blackwood tek 12" radius. CONTROLS volume, tone, bass contour, 3-way. BRIDGE tuneomatic with stop tail. FRETS 22 medium jumbo. STRINGS 10-46. NECK Roasted maple, satin amber finish. TRUSS ROD dual action, headstock access. CASE Two-Toned Teardrop (Available Separately). SCALE 25-1/2". TUNERS Reverend pin-lock
37544568_10155960747244565_2330912411197898752_n.jpg [ 88.85 KiB | Viewed 2150 times ]
