70883
 PRS Core Mira Korina såld
Rare limited edition PRS in mint condition. 100 Core Mira Korina was made in 2009. Sweet upper midrange with extra bite and spank. That neck pick up is to die for when coil tapped!
NU såld kr inklusive Bussgods
An Excellent American PRS with the Rich Tone of Korina!
The Paul Reed Smith Mira Korina solidbody electric guitar brings a combination of old-school vibe and modern construction to the PRS lineup. The Mira Korina features a solid, flat-topped Korina body with a slightly more expressive midrange than mahogany. Distinctive Mira humbucking pickups that can be coil-tapped allow you to arrive at an astounding range of tones. A PRS Stoptail bridge and locking tuners give this great-sounding guitar great tuning stability. Add the fact that it's among the most affordable Maryland-made PRS guitars, and you've got a winner in the versatile Mira Korina! Paul Reed Smith Mira Korina at a Glance:
Distinctive tone
Quality components
A fitting addition to the PRS line
Distinctive tone The Mira Korina's solid Korina body is slightly thinner than that featured on other PRS models. Korina, also known as Limba, is an African wood known for its legendary tonal qualities that add mids to the usually more mellow mahogany sound. The result is a very light guitar with a rich tone that is further enhanced by the versatile Mira humbuckers. These open-coil humbuckers can be coil-tapped to produce an astounding range of tones, from sparkling clean thick overdrive. It gives you the sensation of a purpose-built, stripped-down guitar without sacrificing any of the features, playability, or quality PRS guitars are renowned for. Quality components In addition to the solid mahogany body, 25"-scale Custom 24 Korina neck, and rosewood fingerboard, the Mira Korina features an integrated Stoptail bridge/tailpiece. In concert with the PRS locking tuners, this tailpiece gives the Mira Korina great tuning stability with an efficient, "less-is-more" approach. You can also coax a great range of sounds from the Mira Korina's dedicated Bass and Treble pickups, thanks to a 3-way blade pickup selector and volume and tone controls. A fitting addition to the PRS line All Paul Reed Smith guitars are designed for top-notch performance, right out of the case and the Mira Korina is no exception. Constructed from the finest tonewoods and components, PRS instruments carry on a commitment to quality that's been the brand's hallmark since 1985, when Paul Reed Smith himself started hand-building guitars for some of the most elite players in the world. Paul Reed Smith Mira Korina Features:
Color: Korina / Natural finish
Body: Solid Korina
Neck: Mahogany, Wide-thin carve
Scale: 25"
Fingerboard: Indian Rosewood
Inlays: Moon inlays
No. of frets: 24
Hardware: PRS Stoptail bridge/tailpiece
Tuning machines: PRS 14:1 Phase II low-mass locking tuners
Pickguard: Matching pickguard and truss rod cover
Pickups: Mira Treble and Bass Humbucking pickups with coil tap
Controls: Single volume, single tone, 3-way blade pickup selector, mini coil-tap toggle
Includes hard shell case
The Paul Reed Smith Mira Korina builds old-school feel, modern components, and versatile playability into an affordable U.S.-made guitar!
