[ 3 posts ] |
zeke.tmo
Joined: 20 Mar 2012, 00:05 Posts: 191 Location: Västerås
 Gibson Boost Krets
Är det någon som plockat ur den ur sin les Paul? Och vill sälja den? Helst den som sitter på pott, men mini-toggel varianten funkar. Även bak plattan med batteri förvaringen behöver jag.
Pm, tack.
| 22 Apr 2020, 07:52 |
zeke.tmo
 Re: Gibson Boost Krets
Ingen som har?
| 25 Mar 2021, 16:10 |
pleximaster
The 47k trimmer sets the boost gain. The 4.7pF caps are an educated guess. I think they are just there to avoid RF interference. It was odd but the source terminal of the J202 FET was connected to the 22k load resistor R3. I guess they are interchangeable.
| 25 Mar 2021, 23:08 |
[ 3 posts ] |
Users browsing this forum: No registered users and 41 guests |
