View unanswered posts | View active topics It is currently 05 May 2026, 07:33
Korg AX1500G 800 spänn
Post Korg AX1500G 800 spänn
Kolla länken
http://www.vendolin.se/Annonce_Detail.a ... id=5550368
ToneWorks AX1500G is packed with 56 different effects and gives you everything from ultra-realistic models of great stomp boxes, amps and speaker cabinets to essential effects like chorus, reverb, delay, pitch shift, and more.
Features
48 preset and 48 user multi-effects programs, with up to 8 effects at once
2 selectable channels per program, just like a channel-switching amp
Expression pedal for real-time effects control
Super easy to use. Create the sounds you want by turning a few knobs
Illuminated display for excellent visibility - even on stage
Phrase Trainer makes it easy to learn riffs by ear
Sample & Play function lets you record a phrase and loop or reverse it
Road-rugged metal body and parts
Korg auto-chromatic tuner and metronome built in
Korg's proprietary REMS technology creates the most amazingly realistic digital models of popular effects, amps, and speaker
21 Jan 2009, 10:40
