View unanswered posts | View active topics It is currently 04 May 2026, 11:42
SÅLD
Post SÅLD
Säljer en Marshall Valvestate II VS100R. Stärkaren är i mycket fint skick. Footswitch medföljer ej.
Finns i Kristinehamn, kan skickas med bussgods då köparen står för frakten. Pris: 2000kr. Prutat och klart.
Maila gärna för bilder, frågor mm.
mattias.memfis at hotmail.com
Info från Marshall's hemsida:
* 100 Watt Valvestate power stage driving 1x12'' speaker [VS100R].
* ECC83 [12AX7] Pre-amp valve active on all 3 channels.
* 3 independent footswitchable channels, 'Clean', 'Overdrive 1' and 'Overdrive 2'.
* Clean channel with Treble, Middle and Bass controls, plus Tone Shift switch for extra tonal options.
* Overdrive 1 channel with its own Gain and Volume plus shared EQ with Overdrive 2.
* Overdrive 2 channel with its own Gain, Volume and sweeping Contour control.
* Power Dimension switch to give the effect of the greater saturation of a valve power stage of lower wattage being driven hard.
* Built-in spring Reverb with separate level controls for the Clean and Overdrive 1/2.
* Effects Loop with front panel Mix control.
* Headphone jack [which mutes the internal speaker].
* Line Out jack with Speaker Emulation for connection to external equipment.
* Extension speaker jacks
22 Jan 2009, 01:37
Sänkte priset en femhundring nu.
12 Feb 2009, 16:07
bump.
01 Mar 2009, 16:58
Users browsing this forum: Bing [Bot] and 4 guests
