View unanswered posts | View active topics It is currently 15 May 2026, 07:56
Roger Mayer Spitfire-X och Mongoose-X SÅLDA
Post Roger Mayer Spitfire-X och Mongoose-X SÅLDA
2 st Roger Mayer pedaler från X-serien, dvs de med fatness (ton)-kontroll.
Bägge har det klassiska Roger Mayer - soundet - dvs en dragning åt fuzzhållet och bra respons på gitarrens volymkontroll. Kolla in James Ryans demos så tror jag ni fattar galoppen!!!
Fint skick!
Spitfire
Demos
https://www.youtube.com/watch?v=jhCO3nh-QKY
https://www.youtube.com/watch?v=lW5kjHA2wM8
The Spitfire has been deliberately designed to produce the classic triode tube type distortion that is particularly rich in harmonics that are very musical and pleasing to the ears. This basically means that chords can be used at high levels of distortion without sounding raucous or just plain nasty, as would be the case with other types of fuzz boxes.
The Spitfire maintains the guitars original tone characteristics with the open sound, detail and sonic heritage that have their roots in my association with the making of Jimi's recordings. I have added a few new design twists and coupled with my extensive knowledge from the retro fuzz and distortion boxes we already produce have come up with a new sounding modern distortion/ fuzz sound that does indeed sound fresh and distinctive and not just another boring reissue or clone of a 30year old design.
It has definite advantages that will appeal to those players who strive for a modern sound with strong roots in the past.
The Spitfire is a very Low Noise analogue high gain design, stable, free from radio and other electronic interference that cause so much trouble. It has a greatly increased output level that enables it to overdrive the front end of any amp very hard. Turning up the Gain or Drive control will produce feedback at very low sound levels and a virtually never ending sustain that is very full and tight with the top end staying sweet encouraging soaring string bends and wild solos.
The overall EQ has been carefully developed to produce a well-rounded fatness and musical tone, not the nasal or fizzy thin type of fuzz sound that is common with digital modellers, multi effects etc. Analogue circuitry really does sound better when it comes to high gain low noise situations; there is no contest.
The unit really comes into it's own during live performance situations as it cleans up superbly well using the guitar volume control whilst maintaining the guitars original tone as the signal goes from wild distortion to the original guitar tone. This effective control from the guitar makes life a great deal easier for the live player who likes to change tone effortlessly from his axe.
The Spitfire even when used at high gain levels maintains a very clean transition from note to note that is transparent and free from the usual nasty type of spitting sounds heard so often when the signal decays and a new note begins. This of courses encourages fast solos with lots of sustain that actually sound louder due to the fact that the spaces between the note are not filled up with mush and noise.
The circuit senses and uses electronic information fed directly from the guitar's pickups to control it's own operational parameters and it is recommended to use the Spitfire 1st in the signal processing chain to take full advantage of this internal feedforward feature.
It is this particular feature of the Spitfire that that helps to make it quite different from early fuzz pedals and makes the unit respond very well to each individual players touch, style and playing technique. Five minutes playing with the Spitfire will convince anyone this is not just a re-hashed design but genuinely innovative with some new tone colours.
Mongoose
Demo från 1.33 https://www.youtube.com/watch?v=DRmPCet2ZX4
The Mongoose was developed in 1985 for guitarists who demand a guitar effect with lots of fat fuzz and enough bottom end to keep a metal head happy. The Mongoose also sounds as if it has a pre-set type wah voice that gives the distortion distinctive focus. It has proved popular with a wide and varied type of guitar player from Metal through Rock and Jazz. It is more modern sounding and civilised sounding than the Axis or Classic Fuzz and has found a niche with those who want an alternative but not too radically different sound that the current range of mass-produced units from the USA, Japan and Far East produce.
Electronically the Mongooose uses a combination of both discrete and IC analogue design techniques. The clipping circuit primarily comes from a passive diode circuit resulting in smooth compression and harmonic overtones providing a smooth and transparent transition from clean to overload states. Chords sound very good and with the amazing amount of sustain available, feedback is possible at the lowest amplifier volume settings. These features have made the Mongoose popular in the recording studio and similar situations where feedback is desirable at low sound levels.
Current users include Bono (U2) and Joe Perry (Aerosmith).
900,- (1000,-) styck eller 1600,- (1900,-) för bägge. Ev. frakt tillkommer.
Finns i Nacka men kan även resa in till Hötorget under kontorstid.
21 Sep 2015, 21:48
Post Re: Roger Mayer Spitfire-X och Mongoose-X
bump för två balla pedaler i den fuzzigare skolan
28 Oct 2015, 13:29
Post Re: Roger Mayer Spitfire-X och Mongoose-X SÄNKTA
Prissänkningsbump
06 Feb 2018, 10:50
