View unanswered posts | View active topics It is currently 17 May 2026, 22:19
Dunlop, one control, Xotic, tc electronics, T-rex
Post Dunlop, one control, Xotic, tc electronics, T-rex
samlade på ett ställe ..
TC electronics Nova repeater, SÅLD
"Delay pedal med många funktioner. Taptempo, studio, analog, tape, dynamic, reverse, ping pong, splillover, kill dry mm. "
Xotic BB preamp – SÅLD
“The BB Preamp offers awide variety of sounds. It's capable of a 30dB+ clean boost with an adjustable ±15dB two band active EQ which adds a wide range of harmonic content to your ideal sound.The BB also utilizes a pre-gain stage which allows the Pedal to go from a very pristine clean to a very smooth,compressed, overdriven sound”
T-Rex Möller, BEHÅLLER
Okko Diablo- 1500 :-
“The Diablo is a versatile low to medium gain overdrive with an exceptionally dynamic response. “
One control, white loop – SÅLD
“dubbeloop för två kedjor av pedaler! Växla enkelt mellan två ljud. Den har också 2 st extra DC strömutgångar. “
Dunlop Crybaby original från 80-tal. Stinkfoot-moddad – 800 :-
Tom Sline , Blues, mini pedal, 200 kr
One control - little green emphaser - Björn Juhl design - 750 :-
"Ger lite spark / boost till solo-spel, funkar bra både till singe coil och till humbucker. Funkar också för rena ljud - även som bas-pedal för lite extra crisp ... "
"I'm gonna put a curse on you and all your kids will be born completely naked. " J.Hendrix
01 Feb 2018, 18:26
Post Re: Dunlop, one control, Xotic, tc electronics, T-rex
upp igen ..
18 Feb 2018, 13:31
tralala ...
26 Mar 2018, 21:00
