[ 9 posts ] |
Analog Man Astro Tone Fuzz = SÅLD =
rallyratten
<font size="2"><b>SÅLD</b></font id="size2">
Helt ny fuzzpedal i Fuzz Face-skolan.
Slö som jag är klipper jag in lite info om den från Analog Mikes hemsida. [8D]
******************************************************************** Many people have problems using a Fuzz Face type pedal, like our Sunface, live with a band. I had the same problem which is one reason we are making these pedals, it’s something I need to get the sounds I want. I play Fender amps with a Les Paul, which is not too favorable to fuzz face pedals. But this pedal works great with that setup.
The sound is not as compressed as a Fuzz Face, not SUPER thick and saturated, something between a fuzz and distortion. It’s fuzzier into a smaller amp (Fender Deluxe), and more of a BOOSTER into a large distorted amp (Marshall 1970s Super Lead). It can also be stacked with other pedals, for example running a fuzz face into it can get a sound like Spirit in the Sky, which buzzes and cuts out. Or run the Astro Tone into an OD pedal like a TS808 or KoT to make it fatter.
Features:
1. True Bypass switching 2. Super Bright LED for lower power use, buffed so as not to blind you! 3. Uses less than 1 mA of power when off, only 3 when on, so an Alkaline bat tery will last a few hundred hours of normal playing time. 4. Normal Boss style power jack, negative ground so no polarity problems 5. Three simple knobs - Volume, Fuzz, and Tone. 6. High quality, hand wired RE’AN input and output jacks. 7. original 1966 Fairchild Silicon transistors, not affected by heat like a Germanium fuzz. 8. Sound is not as compressed as a fuzzface, not SUPER thick and saturated, something between a fuzz and distortion but closer to a fuzz. *******************************************************************
Kom med vettiga bud, eller fresta mig med ett bra byte.
| 31 May 2010, 22:45 |
Hyper Pak
mAiL!
| 01 Jun 2010, 01:14 |
rallyratten
Och mail till Hyper Pak...
| 01 Jun 2010, 09:35 |
Hyper Pak
mAiL tebax
| 01 Jun 2010, 20:32 |
konjuk
Joined: 10 Aug 2002, 16:24 Posts: 646 Location: Ångermanland
Kan jag locka med en RC-Booster?
Instant-02 (Konjuk)
| 01 Jun 2010, 20:50 |
rallyratten
konjuk wrote: Kan jag locka med en RC-Booster?
Instant-02 (Konjuk)
Sorry, den är så nära såld den kan vara...[:)]
| 01 Jun 2010, 21:23 |
konjuk
OK. Får man fråga var man kan hitta en sån däringarn pedal? [:)] Måste man ta från staterna?
Instant-02 (Konjuk)
| 02 Jun 2010, 08:47 |
rallyratten
konjuk wrote: OK. Får man fråga var man kan hitta en sån däringarn pedal? [:)] Måste man ta från staterna?
Instant-02 (Konjuk)
Det går jättebra att fråga...[:)] Jag köpte den direkt från tillverkaren. Jag har sett att Thesegoto11 har den upplagd på sin hemsida, men det verkar som att de inte fått hem den ännu.
| 02 Jun 2010, 09:15 |
spindeln
analogman.com är billigt
_______________________________ Har en massa Lavakablar: Pedalbordskit, krullkabel, clear connect - maila mig !
| 02 Jun 2010, 14:55 |
[ 9 posts ] |
Users browsing this forum: No registered users and 10 guests |
