View unanswered posts | View active topics It is currently 11 May 2026, 23:18
Reply to topic  [ 5 posts ]
MusicomLab EFX mkII v3 Effects switcher - Såld
Post MusicomLab EFX mkII v3 Effects switcher - Såld
Grym pedalswitcher för pedalbordet I nyskick (inköpt I våras).
- 8 programmable true bypass effect loops (8 audio loops or 7 audio loops + 1 control function or 6 audio loops and 2 control functions
- Loops 7 & 8 can be reassigned as control functions e.g. for amp switching
- Volume pedal insert point between effect loops 4 & 5
- 25 banks of 4 presets (100 memory locations) plus 1 global preset
- 10 stage anti-popping noise control
- Utilizes two low-noise and high quality buffers to prevent the loss of guitar signal (input buffer can be bypassed)
- Mute switch to mute all outputs
- 1 programmable continuous controller port with programmable MIDI channel and control number
- Transmits 5 MIDI Program Changes on 5 MIDI channels and 8 MIDI Control Change on appointed MIDI channel
- Heavy-duty Carling stomp switches, gold-plated relays and Switchcraft jacks
- Powered by 9Vac or 12Vdc (approx. 400mA) 230Vac/12Vdc adapter included
- Aluminium enclosure
- Dimensions: 220 W x 145 D x 45 FH x 55 RH (mm)
- Weight: 1.2kg
Läs mer här: http://www.musicomlab.co.kr/efxmkii.htm
Pris 3500:-
Kan skickas.
Har även annons på Vend: http://www.vend.se/ad.php?30063
18 Aug 2010, 21:47
Mail skickat!
18 Aug 2010, 21:57
Mail tebaks.
18 Aug 2010, 22:19
Jag tar den om det inte redan blivit affär! Mailar!
musik: http://www.myspace.com/peppermintville
18 Aug 2010, 23:00
Och nu har jag svarat på ditt mail!
19 Aug 2010, 08:46
