Digitalt delay med bland annat holdfunktion, möjlighet att koppla på en taptempopedal, reversemode mm.
säljes för 1000:- inklusive frakt.
http://www.bossus.com/gear/productdetails.php?ProductId=141
The DD-5 offers four switchable delay ranges and 11 modes that give access to delays from 1ms all the way up to a walloping 2000ms. Delay time can also be set in real time using the Tap Tempo function and an optional FS-5U footswitch. With the Hold mode you can sample a passage simply by pressing and releasing the pedal.
• Compact stereo delay pedal with 1ms to 2000ms delay capabilities
• Tap tempo capabilities in real time with optional FS-FU footswitch
• Hold mode for sampling passages
• Reverse mode for new and unique sounds
• AC adaptor or 9V battery operation
