Radial Tonebone Classic Distortion *Bortbytt*
BORTBYTT
Sista chansen. Till helgen byter jag annars bort denna...
Radial Tonebone Classic Tube Distortion (Blå), 950kr.
(Kostar 2280kr + frakt ny hos tysken.)
Prisbelönad distpedal, flera gånger om.
Används bl.a. av Gary Moore, Steve Lukather och Eric Johnson
Inklusive 15V (1000mA) strömadapter (230V/50Hz) i nyskick (ej original). Modell HQ Power PS1510. Korrekt volt och tillräcklig ampere för att klara belastningen med lätthet. Adaptern är även skyddad mot övertemperatur och kortslutning. 1.85 meter lång kabel. (bild längre ned)
Kanonpedal, speciellt med boost.
Inte riktigt mitt ljud, därför släpper jag den.
Begagnad men i jättefint skick. Allt komplett med kartong och garanterat helt fungerande. Kardborre under både pedal och strömadapter.
Finns i Uppsala.
Kan skickas.
Tillverkarens info:
http://tonebone.com/tb-classic.htmQuote:
12AX7 tube for natural overdrive tone
True bypass clean mode
Powerful EQ for wide tonal range
Ultra low-noise - amazing dynamics and feel
Cleans up like a tube amp when guitar turned down
The Tonebone Classic is a 12AX7 tube equipped true-bypass distortion that has been optimized for flexibility and tonal range.
Following the vision set by Leo Fender in the 1950’s, the Classic is based on vintage overdrive sounds that started in the '60s and '70s and today remain some of the most sought after tones. With three drive settings, variable drive control and powerful EQ, the Classic lets you dial in the slight overdrive to high-gain saturation and everything in between.
And like a real tube amp, when you turn your guitar volume down, the Classic cleans up naturally - without the noise, hum or buzz that is common with most other pedals. At higher settings, every note remains distinct. The Classic is so responsive and dynamic your playing style shines through!
The Radial Tonebone Classic – the most dynamic and responsive distortion pedal ever!
