View unanswered posts | View active topics It is currently 17 May 2026, 12:51
PRS S2 VELA Limited edition
Post PRS S2 VELA Limited edition
Fantastisk gitarr från 2016 i absolut nyskick.
Type D Single coil (PRS designed DeArmond) i halsen och en Starla Humbucker (med coil split) i stall.
25" skala, 22 band, satin finish.
NU 10.500 kronor inklusive Bussgods. BVSA
https://www.prsguitars.com/index.php/el ... _vela_2018
https://www.premierguitar.com/articles/ ... ela-review
Ratings
Pros:
Incredible bang for the buck. Impeccably built. Curvy good looks. Beautifully dynamic and sensitive.
Cons:
None
https://guitar.com/review/prs-s2-vela-review/
PRS Paul Reed Smith S2 Vela Satin Limited Electric Guitar McCarty Tobacco Sunburst w Gig Bag
This S2 Vela Satin Limited is a vintage-inspired guitar with loads of personality and tonal textures. The Vela boasts an offset body shape that is both elegant and edgy. The addition of a satin nitro finish for this limited edition gives the Vela added attitude and resonance and a truly addictive feel.
Its pickguard-loaded electronics features a PRS-Designed Starla pickup in the bridge, providing a bright, punky tone, and the PRS-Designed Type-D Singlecoil in the neck that gives the Vela noteworthy bite. The coil-tap on the tone control allows the bridge pickup to split to singlecoils, providing a balanced tone that will cut through the mix with style.
Anchoring this guitar is the PRS plate-style bridge with two saddles that were designed to compensate for intonation. This bridge harkens back to Paul’s early designs and traditional bass plate-style bridges, but is top-loading for easy restringing. Like the bridge found on Paul’s Guitar and some Private Stock models, PRS’s new plate-style bridge features brass saddles and an aluminum plate for maximum tonal sustain.
Features:
All Mah body with Satin Nitro finish in Vintage Cherry
Mah neck
Hum/Single pickup configuration
PRS-Designed Starla bridge pickup
PRS-Designed Type-D Singlecoil neck pickup
PRS gig bag included
06 Apr 2019, 15:05
