Fenders egna rekommendationer för olika mickar är en bra utgångspunkt. Men lite finjustering måste man nästan alltid göra ändå.
PICKUPS
Set too high, pickups can cause myriad inexplicable phenomena. Depress all the strings at the last fret. Using a 6" (150 mm) ruler, measure the distance from the bottom of the first and sixth strings to the top of the pole piece. A good rule of thumb is that the distance should be greatest at the sixth-string neck pickup position, and closest at the first-string bridge pickup position. Follow the measurement guidelines in the chart below as starting points. The distance will vary according to the amount of magnetic pull from the pickup.
Bass Side Treble Side
Texas Specials 8/64" (3.6 mm) 6/64" (2.4 mm)
Vintage style 6/64" (2.4 mm) 5/64" (2 mm)
Noiselessâ„¢ Series 8/64" (3.6 mm) 6/64" (2.4 mm)
Standard Single-Coil 5/64" (2 mm) 4/64" (1.6 mm)
Humbuckers 4/64" (1.6 mm) 4/64" (1.6 mm)
Lace Sensors As close as desired (allowing for string vibration)
/Uffe
- The Mayor of Simpleton -
http://www.guitarlabs.se
