View unanswered posts | View active topics It is currently 24 Sep 2026, 14:03
Reply to topic  [ 5 posts ]
Vox AC4 Mod KIT
Post Vox AC4 Mod KIT
The BitMo VoxMo4 mod kit for the Vox AC4TV head or combo amp does not try to make the amp into something else, just a bitmo better Vox. The kit includes a JAN Philips 12AT7WC preamp tube. With this amp, it makes a huge difference, extends the range of the controls and smooths everything out.
The BitMo VoxMo4 kit also adds a switch with 3 different voicings, making the amp much more versatile. The middle position is the (upgraded) stock configuration. The low position shifts toward a smooth treble, tightens the bass, increases the headroom and provides that “Vox jangle” perfect with your Rickenbacker 12 string for Byrds and Beatles. The 3rd position shifts the mid frequencies down and raises the gain a bit for a stout clean or overdrive that can go from crunch to chocolaty brown cello sound to a tight, biting boost – think Stones and Beatles. All 3 voicings are very touch sensitive and great across the full range of the volume control, going from warm or sparkly clean to all out overdrive with lots of interesting shades in between, all with that magical Vox midrange.
Allt är nytt oanvänd i kartong, hann sälja stärkaren innan modded kom fram från USA
300:-
03 Mar 2012, 16:45
Post Re: Vox AC4 Mod
byte mot en sån här?
http://www.gnu.se/peterson/peterson_vs1.htm#vs-2
"Constipated people don't give a crap"
04 Mar 2012, 12:46
Post Re: Vox AC4 Mod KIT
Tack men nej tack.
mvh Cabbe
09 Apr 2012, 23:13
Måste man in o löda o greja för denna modd?
10 Apr 2012, 23:41
Japp lite måste man lödda men inte greja.
10 Apr 2012, 23:50
