View unanswered posts | View active topics It is currently 22 Sep 2026, 14:27
Yamaha CP-30 elpiano bortskänkes...BORTA!
Post Yamaha CP-30 elpiano bortskänkes...BORTA!
Först till kvarn...
Gissningsvis 70-tals Yamaha, viktade trätangenter, sustainpedal samt tremolopedal (har jag för mig). Tror allt funkar. Använts som "bord" senaste åren.
Det delade caset blir benställning.
Från nätet:
There's three different "piano" sounds and a harpsichord sound with adjustable bass, treble, and tremolo. You can combine two sounds together at the same time and adjust the volume and pitch of each sound independently, so you can create custom sounds. The sound is pretty cool--it's very percussive with a hard front edge followed by a softer sustain. I've heard comparisons of the sound to that of a Hohner Pianet before, though I'm not certain about that. It doesn't really sound like anything else! With a wah and distortion pedal, you can get a pretty cool sound out of it that almost mimicks an electric guitar (almost). Also, using a bit of chorus can really fatten up the sound. Mixing one of the pianos and a touch of harpsichord can give you a sound reminiscent of a clavinet, though obviously not the same.
Tung som fan, tre trappor utan hiss, finns i Falun. Ta med bärhjälp, tänker inte hjälpa till för det utsatta priset.
14 Jul 2012, 11:14
