| Ljudbojen.com https://www.ljudbojen.com/ |
| LOTTO - Orville by Gibson LPS 57C Reissue -Såld https://www.ljudbojen.com/viewtopic.php?f=1&t=122875 |
Page 1 of 1 |
| Author: | SLA [ 10 Mar 2019, 16:28 ] |
| Post subject: | LOTTO - Orville by Gibson LPS 57C Reissue -Såld |
Orville by Gibson LPS 57C Reissue ---------------------------- Mahogny bakstycke. Solid lönn-topp Long tenon Fret edge bindning Nitro-lack Classic 57 - humbuckers Nickel mekanik ABR-1 stall Japansk Gibson Les Paul Reissue tillverkad av Fujigen. Serienummer:405833 = 1994 RI 4.7 kg spelmässig? Som en bra Gibson när du har turen att hitta en Påminner om min gamla Gibson Les Paul 1960 classic 2002, men fetare hals, bättre balans och bättre mickar. ![]() ![]() 1: 2: oakn 3: Kardinalen 4: Fyris 5: AndreasO 6: 7: 8: TrySoft 9: harumanu 10: sebulba 11: harumanu 12: EmilK 13: Daz_j 14: Obi 15: PelleMustaine 16: os72 17: 18: 19: 20: 21: crille80 22: tobias sundberg 23: 24: @tommypistolen 25: 26: leffje 27: 28: TrySoft 29: 30: 31: 32: Azumi 33: billy bob 34: 35: |
| Author: | SLA [ 18 Mar 2019, 09:32 ] |
| Post subject: | Re: Orville by Gibson LPS 57C Reissue Wine Red 1994 -LOTTO ? |
Intresse för att köra Lotto på denna - bump? |
| Author: | TrySoft [ 18 Mar 2019, 15:07 ] |
Hej, Alltid med, jag tar 8 och 28 om det blir av. /Trysoft |
| Author: | SLA [ 18 Mar 2019, 15:14 ] |
coolt |
| Author: | Fyris [ 19 Mar 2019, 00:54 ] |
Jag är på. Nummer 4! |
| Author: | crille80 [ 19 Mar 2019, 01:18 ] |
#21 tack. |
| Author: | leffje [ 19 Mar 2019, 07:56 ] |
| Post subject: | Re: LOTTO - Orville by Gibson LPS 57C Reissue Wine Red 1994 |
Nr:26 tack |
| Author: | billy bob [ 19 Mar 2019, 14:18 ] |
Jag tar 33 tack |
| Author: | EmilK [ 19 Mar 2019, 14:36 ] |
Jag tar nr.12 tack! |
| Author: | harumanu [ 19 Mar 2019, 15:34 ] |
Tar nr 11! |
| Author: | Kardinalen [ 20 Mar 2019, 07:32 ] |
Nummer 3 tack! |
| Author: | @tommypistolen [ 20 Mar 2019, 09:26 ] |
Tar lott 24. |
| Author: | Daz_j [ 20 Mar 2019, 21:21 ] |
Nr 13 tack |
| Author: | tobias sundberg [ 22 Mar 2019, 13:01 ] |
Nr 22 tack |
| Author: | sebulba [ 23 Mar 2019, 19:35 ] |
Tar nr 10, tack. |
| Author: | AndreasO [ 25 Mar 2019, 16:20 ] |
Jag tar gärna nummer fem (5) |
| Author: | PelleMustaine [ 25 Mar 2019, 18:28 ] |
Jag tar nummer 15 |
| Author: | os72 [ 26 Mar 2019, 12:55 ] |
Nr 16, tack! Os72 |
| Author: | Azumi [ 26 Mar 2019, 19:29 ] |
Nr 32 / Azumi |
| Author: | Obi [ 27 Mar 2019, 00:34 ] |
Vilken goding. Jag tar nummer 14 på den tack! |
| Author: | SLA [ 05 Apr 2019, 09:40 ] |
Lite långsamt..? Fredagsbump |
| Author: | oakn [ 05 Apr 2019, 16:43 ] |
Ja, lite långsamt går det. Jag kan ta nr 2. |
| Author: | harumanu [ 05 Apr 2019, 17:13 ] |
tar nr 9 också! |
| Author: | SLA [ 14 Apr 2019, 15:15 ] |
Intresset verkar inte jättestort för lottot Satt in annons för två dar sedan och nu är den såld.. |
| Author: | Polytone [ 14 Apr 2019, 18:49 ] |
| Post subject: | Re: LOTTO - Orville by Gibson LPS 57C Reissue -Såld |
Bra. |
