https://www.ljudbojen.com/
Victoria Tweed Twin - 14500 kr !!!!!!!!!!!
https://www.ljudbojen.com/viewtopic.php?f=25&t=21949
Author:  spindeln [ 09 Dec 2008, 23:36 ]
Post subject:  Victoria Tweed Twin - 14500 kr !!!!!!!!!!!
2x12 combo, switchbar mellan 25 och 50 watt. Fantastiskt fender ljud som spricker upp lite åt marshall hållet när man drar på volymen. Liknar -57 reissue fender twin fast låter bättre enligt mig. 110 volt, strömmvandlare ingår. Älskar pedaler. Point to point, superkvalitet, har gått som tåget de 3 år jag haft den.
Wattage: 50 Watts
5E8A-type circuit.Class A-B adjustable fixed bias push-pull operation.Tube complement:1-5AR4, 2-6L6GC, 2-12AX7, 2-12AY7
The 5E8-A "low power" Twin remains the most coveted 50W tone monster in the history of guitar amplifiers. The transformers are Hi watt-huge, that means thundering, rock-solid lows with no sag whatsoever, and the smoothest, creamiest highs ever wrapped in tweed. This is our tightest and most percussive amp, A long-time favorite here at Victoria. Turn it up!
Mycket fint skick, pris: <s>19000 kr</s> <s>17900 kr !!!! </s> (nypris 30000 kr)
<s>NU 16000 kr !!!! </s>billigare blir den inte, då får jag behålla den...<NU 15000 kr ! bytes bort om ingen nappar nu, årets stärkarfynd.
<font size="6">NU 14500 kr !!!</font id="size6">
byten som kan vara intressanta: gammal fender jaguar/jazzmaster/telecaster, space echo 301, klon centaur
inte min på bilden, min har gamla victoria loggon.
maila ollenorin@yahoo.se
eller ring 0736-200863
Author:  spindeln [ 11 Dec 2008, 20:59 ]
Post subject:
<font size="6">Pris: 17900 kr !!!
nypris 30000 kr
</font id="size6">
Author:  spindeln [ 27 Dec 2008, 19:38 ]
Post subject:
bump
Author:  rag [ 29 Dec 2008, 00:31 ]
Post subject:
detta blir man ju sugen på!!!! inga svängar till götet i det närmaste eller? skulle vara kul att testa.
Author:  spindeln [ 29 Dec 2008, 01:14 ]
Post subject:
tyvärr inga turer till Göteborg inplanerade.....kan skickas med Bussgods dock.
eller nån kanske har nåt att byta mot ?
gammal jaguar/jazzmaster/telecaster/space echo/fulltone eko
Author:  spindeln [ 30 Dec 2008, 12:50 ]
Post subject:
bump
Author:  spindeln [ 03 Jan 2009, 16:43 ]
Post subject:
bump
Author:  spindeln [ 07 Jan 2009, 02:25 ]
Post subject:
bjmp
Author:  spindeln [ 15 Jan 2009, 01:05 ]
Post subject:
bump
Author:  spindeln [ 04 Jul 2009, 21:40 ]
Post subject:
en norrman som åkte från oslo och kom mitt i natten.
Author:  spindeln [ 05 Jul 2009, 09:55 ]
Post subject:
en hiwatt dr504......ruskigt grym stärkare. Om du vill ha det fetaste rena ljudet men superpunch och sen kunna addera pedaler till så är den världens bästa för det.
Det är inget distmonster.
