| Ljudbojen.com https://www.ljudbojen.com/ |
| Fuchs Lucky 7 https://www.ljudbojen.com/viewtopic.php?f=25&t=26101 |
Page 1 of 1 |
| Author: | melander [ 19 Apr 2009, 14:30 ] |
| Post subject: | Fuchs Lucky 7 |
The Lucky 7® brings the high build quality and awesome tones people expect of Fuchs products to a new more affordable price range. The Lucky 7® is based on a dual 12AX7 preamp stage and a unique single ended 7-watt EL-34 fixed bias output stage. By switching to a 6V6, you can reduce power to less than 5-watts. Unlike other amps in this price range, the Lucky 7® has a full complement of extremely flexible tone controls. A surprising amount of clean headroom is available before the output stage begins distorting with a sweet yet cutting rock edge. Voiced like its bigger siblings the Train 45â„¢ and Blackjack 21®, the Lucky 7® has a classic rock voice similar to a vintage Marshallâ„¢ or Trainwreckâ„¢ style amp. It provides a cutting rock edge, yet filled with harmonic richness and chime. The circuit design also is "attenuator friendly". The Lucky 7® and its higher powered sibling the Blackjack 21® have a preamp stage designed to allow clean-to-mean from the guitar volume control. The chassis (like all Fuchs products) is aircraft grade aluminum; our internal construction is mixed PC board and hard wired. On the Lucky 7® and Blackjack 21®, the preamp tubes and power supply circuitry are on the circuit card, while the power tubes and transformer are mounted on the chassis. A detachable power cord is standard. By using single point grounding, the amp is quiet and free of hum at all operating levels. ![]() Mer info och ljudklipp finns här:http://www.fuchsaudiotechnology.com/products-luckyseven.php Videoklipp från mig och ett från ett liveframträdande: http://www.youtube.com/watch?v=S0fVhuFu66E http://www.youtube.com/watch?v=bU-CDa22 ... re=related <s>6500:-</s> <s>6000:-</s> 5500:- |
| Author: | melander [ 25 Apr 2009, 09:52 ] |
| Post subject: | |
Helg bump! |
| Author: | melander [ 08 May 2009, 17:06 ] |
| Post subject: | |
Bump |
| Author: | Tribal_Tech [ 22 May 2009, 09:30 ] |
| Post subject: | |
Hej! Min gamla fuchs, fin förstärkare! MvH Daniel http://www.myspace.com/badsneakersmusic |
| Author: | jros [ 02 Jun 2009, 21:59 ] |
| Post subject: | |
Mail! |
| Author: | melander [ 07 Sep 2009, 08:09 ] |
| Post subject: | |
Bump! Den förtjänar att bli spelad på istället för att bara stå och samla damm, så kom och köp! [:D] |
| Author: | melander [ 27 Oct 2009, 13:30 ] |
| Post subject: | |
Bump! |
| Author: | Hoffe [ 06 May 2010, 19:33 ] |
| Post subject: | |
Byte? http://www.ljudbojen.com/bojen/topic.asp?TOPIC_ID=40210 /Thomas |
| Author: | melander [ 07 May 2010, 11:12 ] |
| Post subject: | |
Hoffe wrote: Tyvärr inte intressant, vill HELST ha cash. |
| Author: | melander [ 24 May 2010, 14:44 ] |
| Post subject: | |
Bump! |
| Author: | melander [ 20 Jun 2010, 15:57 ] |
| Post subject: | |
Kom igen nu! Bump! |
| Author: | Plexiglas [ 20 Jun 2010, 20:08 ] |
| Post subject: | |
hittar en ny på ebay för 699 dollar... finns det mer att göra på priset är jag intresserad! Cash finns. Maila gärna på knuhas@hotmail.com [;)] http://www.myspace.com/gudarsskymning |
| Author: | westhammer [ 22 Sep 2010, 09:53 ] |
| Post subject: | |
Byta mot Fulltone Choral flange + fulldrive2 mosfet? |
| Author: | melander [ 22 Sep 2010, 21:46 ] |
| Post subject: | |
westhammer wrote: Byta mot Fulltone Choral flange + fulldrive2 mosfet? Tack men nej tack! Cash is king just nu[8D] |
| Author: | Plexiglas [ 23 Sep 2010, 19:51 ] |
| Post subject: | |
bjuder 4500! http://www.myspace.com/gudarsskymning Hendrix interview shortly after Woodstock..... Interviewer: "So Jimi - what's it like to be the best guitar player in the world?" Jimi: "Dunno, go and ask Rory Gallagher....." |
