https://www.ljudbojen.com/
T-Rex Diva Drive Sänkt pris
https://www.ljudbojen.com/viewtopic.php?f=30&t=108993
Author:  i_Slash [ 29 Apr 2016, 08:09 ]
Post subject:  T-Rex Diva Drive Sänkt pris
T-rex Diva Drive
Tjena!
Säljer nu en super pedal, nyskick i kartong jag är enda ägaren knappt använd.
VERSATILE PREMIUM OVERDRIVE
The most musical drive out there, DIVA adds all the edge
you want without ever threatening your core sound.
Gorgeous “JRC4558” overdrive gain
Adds juice, but leaves core tone intact
Virtuoso performance at any gain level
Mix in clean signal for extra punch
3 low-end boost options match any guitar
FINALLY, A DRIVE THAT SOUNDS JUST LIKE YOU
DIVA was built to enhance your sound—not replace it. No matter how much gain you add, no matter how you choose to beef up your low end, DIVA will respect your musicianship, your gear and your personal tone. Use it for that subtle “one more notch” effect. Or lay on the gain for some serious, punchy bite. Any way you use it, you’ll sound amazing, just like you.
1000:-
Eller byte/delbyte mot Strymon flint eller el cap
någon fuzz, nån od/dist eventuellt modulations pedaler.
Author:  i_Slash [ 11 May 2016, 11:48 ]
Post subject:  Re: T-Rex Diva Drive
upp!
Author:  i_Slash [ 24 May 2016, 13:53 ]
Sänk pris
