https://www.ljudbojen.com/
Handbyggd Boost från JHS Sänkt Pris
https://www.ljudbojen.com/viewtopic.php?f=30&t=108994
Author:  i_Slash [ 29 Apr 2016, 08:10 ]
Post subject:  Handbyggd Boost från JHS Sänkt Pris
JHS Mini Bomb Handbyggd boost!
Hej, säljer nu en jhs mini bomb boost nyköpt på TGT11 av mig, kanppt använd.
A good booster is often the most underrated tool a guitarist can own. When placed before your overdrives or distortions, a thicker, stronger and more saturated tone can be achieved. When placed after, you get your exact same tone except louder. This is great for lead passages and for causing a tube amp to naturally overdrive due to its huge amount of headroom. You will notice a slight touch of presence that lets your tone cut through the mix for those passes that you really want to stand out. When wide open, the Mini Bomb Boost will give you up to 16dB gain. Chords are heard with clarity and subtle harmonics shine! The Mini-Bomb JFET boost can do all this and only takes up a small 1.5"x3.5” spot on your pedal board!
900:-
Eventuella byten är nån od/dist/boost Strymon El Cap eller Flint samt nån modulation pedal.
Author:  i_Slash [ 11 May 2016, 11:48 ]
Post subject:  Re: Handbyggd Boost från JHS
upp!
Author:  i_Slash [ 24 May 2016, 13:52 ]
Post subject:  Re: Handbyggd Boost från JHS Sänkt Pris
Sänkt pris
