| Ljudbojen.com https://www.ljudbojen.com/ |
| Earthquaker Devices EQD Speaker Cranker V2 https://www.ljudbojen.com/viewtopic.php?f=30&t=116763 |
Page 1 of 1 |
| Author: | 70883 [ 24 Sep 2017, 10:31 ] | ||
| Post subject: | Earthquaker Devices EQD Speaker Cranker V2 | ||
Fantastisk low to medium gain OD. Absolut nyskick med allt som följde med. The Speaker Cranker is a discrete, all-analog distortion enhancement device (i.e. not a booster) designed to give your signal some extra grit and a slight boost without drastically altering your tone. Think of it as sticking an extra preamp tube in your amplifier for more overdrive. Single notes will blossom and bloom with rich harmonics and responsive tube-like sag. Power chords will sound thicker and crunchier, a little more ragged around the edges. Complex chords will remain distinct and complex, as the Speaker Cranker is designed to preserve your tone’s integrity without muddying up the low-end, or “rounding out” the mids, or adding any top-end “shimmer,” or “sparkle,” or any of that other garbage. It’s your tone. Cranked. Ya got that? Guitar World: The “More” knob dials in the amount of dirt, with overdrive creeping in around 9 o’clock on an amp set to clean. The Speaker Cranker is true bypass and operates on 9-volt battery or an optional 9-volt regulated power supply. I find that the Speaker Cranker is an essential stompbox if you use a single-ended amplifier, such as the Marshall JCM 800, or a two-channel amp with a rhythm and lead channel to deliver much-needed gain for harmonics and solos. The pedal does color your sound, but in a good way, slightly darkening the tone to take out any high-end harshness. The gain isn't overwhelming and offers just the right amount of bite if your amplifier is already overdriven. If you’re running the amp clean, the “More” control will add some roundness, compression and grit as you move the knob toward noon and finally overdrive past that — just enough to sustain notes. Check back again as I will be certainly covering more of EarthQuaker’s fantastic pedals. 1200 kr inklusive REK.
