| Ljudbojen.com https://www.ljudbojen.com/ |
| MusicomLab EFX mkII v3 Effects switcher - Såld https://www.ljudbojen.com/viewtopic.php?f=30&t=44420 |
Page 1 of 1 |
| Author: | Pettan [ 18 Aug 2010, 21:47 ] |
| Post subject: | MusicomLab EFX mkII v3 Effects switcher - Såld |
Grym pedalswitcher för pedalbordet I nyskick (inköpt I våras). - 8 programmable true bypass effect loops (8 audio loops or 7 audio loops + 1 control function or 6 audio loops and 2 control functions - Loops 7 & 8 can be reassigned as control functions e.g. for amp switching - Volume pedal insert point between effect loops 4 & 5 - 25 banks of 4 presets (100 memory locations) plus 1 global preset - 10 stage anti-popping noise control - Utilizes two low-noise and high quality buffers to prevent the loss of guitar signal (input buffer can be bypassed) - Mute switch to mute all outputs - 1 programmable continuous controller port with programmable MIDI channel and control number - Transmits 5 MIDI Program Changes on 5 MIDI channels and 8 MIDI Control Change on appointed MIDI channel - Heavy-duty Carling stomp switches, gold-plated relays and Switchcraft jacks - Powered by 9Vac or 12Vdc (approx. 400mA) 230Vac/12Vdc adapter included - Aluminium enclosure - Dimensions: 220 W x 145 D x 45 FH x 55 RH (mm) - Weight: 1.2kg Läs mer här: http://www.musicomlab.co.kr/efxmkii.htm Pris 3500:- Kan skickas. Har även annons på Vend: http://www.vend.se/ad.php?30063 --------------------- |
| Author: | toneking [ 18 Aug 2010, 21:57 ] |
| Post subject: | |
Mail skickat! |
| Author: | Pettan [ 18 Aug 2010, 22:19 ] |
| Post subject: | |
Mail tebaks. --------------------- |
| Author: | svanangen [ 18 Aug 2010, 23:00 ] |
| Post subject: | |
Jag tar den om det inte redan blivit affär! Mailar! musik: http://www.myspace.com/peppermintville |
| Author: | toneking [ 19 Aug 2010, 08:46 ] |
| Post subject: | |
Och nu har jag svarat på ditt mail! |
