https://www.ljudbojen.com/
Intressekoll Musicomlab EFXmkII v3.0 SÅLD!
https://www.ljudbojen.com/viewtopic.php?f=30&t=59878
Author:  es-347 [ 27 Jun 2011, 22:27 ]
Post subject:  Intressekoll Musicomlab EFXmkII v3.0 SÅLD!
Jag överväger att göra om lite i pedaleriet, rack hägrar.
Tänkte kolla om det finns intresse för min looper/midicontroller.
8 programmable true bypass effect loops (8 audio loops or 7 audio loops + 1 control function or 6 audio loops and 2 control functions
- Loops 7 & 8 can be reassigned as control functions e.g. for amp switching
- Volume pedal insert point between effect loops 4 & 5
- 25 banks of 4 presets (100 memory locations) plus 1 global preset
- 10 stage anti-popping noise control
- Utilizes two low-noise and high quality buffers to prevent the loss of guitar signal (input buffer can be bypassed)
- Mute switch to mute all outputs
- 1 programmable continuous controller port with programmable MIDI channel and control number
- Transmits 5 MIDI Program Changes on 5 MIDI channels and 8 MIDI Control Change on appointed MIDI channel
- Heavy-duty Carling stomp switches, gold-plated relays and Switchcraft jacks
- Powered by 9Vac or 12Vdc (approx. 400mA) 230Vac/12Vdc adapter included
- Aluminium enclosure
- Dimensions: 220 W x 145 D x 45 FH x 55 RH (mm)
- Weight: 1.2kg
Manual på min version finns här
http://www.musicomlab.co.kr/pdf/efxmkii ... ver30e.pdf
Mvh/Bengt.
Author:  Elmwood [ 28 Jun 2011, 05:34 ]
Post subject:
Har en sådan, rekommenderas verkligen!!
- Weight: 1.2kg
Mvh/Bengt.
Author:  es-347 [ 28 Jun 2011, 11:30 ]
Post subject:
Tack för gratisreklamen :)/B
Author:  Matte [ 28 Jun 2011, 16:59 ]
Post subject:
Vad har du tänkt dig för pris?
<font size="1">I play pretty loud onstage, mainly because there's a wild ape on the drums.<i> -Scott Henderson"]</font id="size1">
Author:  es-347 [ 28 Jun 2011, 19:11 ]
Post subject:
Den är lite on hold nu , har fått bytesförslag, pris är lite svårt , den är bra och jag sitter inte i sjön. Beror lite på vad jag hittar för alternativ. Kan väl nämna att jag köpt den beg av toneking för 3800 för några månader sedan.
Mvh/B
Author:  es-347 [ 02 Jul 2011, 14:21 ]
Post subject:
Tack för visat intresse, switchen är nu bytt/såld /Bengt
