View unanswered posts | View active topics It is currently 03 May 2026, 06:06
Reply to topic  [ 9 posts ]
Pedaler mm
Post Pedaler mm
Sparkle Drive moddad av Keeley 900:- lite dings.
Catalinbread Silver kiss mk2 1100:- grym lowgain od/ boost som inte tillverkas längre. Bra skick, några dings. SÅLD
http://www.youtube.com/watch?v=fkhSyObTv8Q
Rocktek analog delay 300:-
Dunlop Cry baby wha wha ca -89/-90 moddad med switch på sidan för bredare svep 400:-
Boss FS-5U perfekt till taptempo såld!
K&M Rackhylla utdragbar 900:-
4 enh rackcase (dj producer) 600:-
Bilder(ganska kassa) kan mailas om intresse finns.
Skickas helst inte.
Staffan 0707-985956
staffan@carvercombo.com
11 May 2010, 21:28
Mail!
myspace.com/slackervillezoo
11 May 2010, 21:40
Hej,
vad är det Keeley gör med Sparkle Drive? Skillnad mot en orginal (som jag gillar f ö)?
Matte
mslcases@gmail.com
takestwokultur@tele2.se
13 May 2010, 12:04
Svar till Clapton71, från Keeleys sida.
Our Sparkle Drive mods affect only the drive side of the pedal. The blend control will still function in the same way offering you the most flexibility. But, you will able to get an even cleaner sound because we modify the range of the drive circuit in two ways. We also add the ability to get more drive, almost 2 times the amount of drive. You will have an expanded range of drive possible now! We add a diode to simulate tube-type distortion so the pedal sounds a little more natural. We increase the bass response so it is not cut off when you engage the pedal by adding some nice metal film caps. Lastly the led is change to the cool BLUE LED! We use metal film resistors just like voodoo labs so the quality is the same or higher.
ALLA NI SOM MAILAT MIG: DET GÅR INTE ATT LÄSA ERA MAIL SÅ SKICKA FRÅN ERA EGNA E-POSTADRESSER SÅ KONTAKTAR JAG ER.
MVH STAFFAN.
13 May 2010, 12:57
Jag tar Sparkle drive!!
13 May 2010, 13:07
Såld?
14 May 2010, 08:44
Rambler wrote:
Såld?
mail skickat!
14 May 2010, 16:01
svar
14 May 2010, 19:32
