View unanswered posts | View active topics It is currently 15 May 2026, 18:06
Seymour Duncan SFX03 TwinTubeClassic,*SÅLD*
Post Seymour Duncan SFX03 TwinTubeClassic,*SÅLD*
Köp inget transistortjafs,Diodklippare, det här är rör. Overdrive/distorsion, ger två extra kanaler till din stärk.
Drivs av 15-16VAC (eliminator) som ger de två rören i den extra skjuts istf taniga 9v som vissa andra rörOD's har. Volymen börjar på minus! kan alltså fungera som en ljudsänkare.
Ligger mer åt creamy(/crunch hållet.
[img][IMG]http://i107.photobucket.com/albums/m296/rudmark/SFX-03/3m83o13lc5V35W65X3a8j02665f1a986e16a7.jpg[/img][/img]
[img][IMG]http://i107.photobucket.com/albums/m296/rudmark/SFX-03/images.jpg[/img][/img]
[img][IMG]http://i107.photobucket.com/albums/m296/rudmark/SFX-03/Seymour-Duncan-Twin-Tube-Classic-Back.jpg[/img][/img]
<i>The controls couldn’t be much easier: there’s an ON/BYPASS footswitch (with true bypass circuitry) for turning the device off and on, a CHANNEL SELECT footswitch for moving between the two overdrive channels (Rhythm and Lead,) separate VOLUME and GAIN knobs for each of the channels, and a single set of BASS and TREBLE knobs for setting your desired tone. The back panel is as simple as simple can be: Input, Output, that’s it.
Seymour-Duncan-Twin-Tube-Classic With two channels on-board, plus a bypass footswitch in easy reach, the Twin Tube Classic essentially gives you access to three different pre-sets –– your amp’s clean tone, the pedal’s Ryhthm overdrive channel, and of course the Lead overdrive channel
The SFX-03 Twin Tube Classic preamp pedal delivers all the gain and smooth tone you'd expect from a high-quality tube preamp. The high-plate voltage and 100% vacuum tube signal path allow the 2 - 6021 dual-triode tubes to operate at their fullest potential and provide maximum dynamic range. Two channels expand the tonal possibilities of this preamp even more, from glassy, smooth clean tones to warm crunch with tons of bite. Power supply included.
Seymour Duncan SFX-03 Twin Tube Classic Preamp Pedal Features:
* Uses two premium, military-spec, subminiature, USA-made Philips-Sylvania 6021 dual-triode tubes
* High-plate voltage
* 100% vaccum tube signal path
* Two channels
* True bypass
* Fully encapsulated toroidal transformer for quiet operation
* Heavy-duty steel chassis"]
Ljudexempel
http://img3.musiciansfriend.com/dbase/m ... tube_1.mp3
http://img3.musiciansfriend.com/dbase/m ... tube_2.mp3
Nypris uppåt 2500, <b>säljes för 900 , frakt ingår.</b>
Har faktiskt två, därför får denna gå
<s></s>
30 Oct 2010, 19:44
Hej! Är den kvar? MVH, Mel
14 Dec 2010, 17:53
