View unanswered posts | View active topics It is currently 04 May 2026, 15:07
Jampedals custombygge- Uppe igen!!
Post Jampedals custombygge- Uppe igen!!
På grund av en oseriös köpare (Ingen ljudbojare såklart [:D]) Så lägger jag upp detta objekt igen. Har fått GAS på en bas jag vill köpa, så jag säljer den för en bråkdel av priset i hopp om att den går fort.
Vintagebetonade pedaler i samma chassi, Delay, vibe, tremolo och overdrive, eliminator ingår ej.
info om pedalerna saxat från hemsidan;
THE CHILL TREMOLO
Vintage, sine-wave, analog tremolo, made with carbon comp resistors.
It can also be used as a clean boost ! Just set the Depth control to zero, and adjust the Level to your preference.
DELAY LAMA
A fully analog lo-fi Delay, with a maximum delay time of 600ms. It features BBD analog chips, faithful reproductions of the Panasonic MN3205.
RATTLER+ Overdrive
Featuring the extremely rare LM308 can version chip, Rattler+ offers a unique tone, transparent "Ratty" overdrive and less gain than the classic. With the extra switch you have the choice for extra gain, which brings you closer to the Rattler classic.
RETRO VIBE
An original UniVibe clone with an added twist !
The original UniVibe uses 4 photocells surrounding a pulsating light source to deliver its very unique and recognizable sound...a thick chorus/vibrato type of effect starting off with a slow watery type swirl gradually becoming more 'alive' as the speed knob is manipulated clockwise resulting in a 'machine-gun' type warble around the 9 o'clock setting.
Our aim was to achieve the original sound of the UniVibe, having always as reference an Original '69 UniVibe.
Får jag <font color="red">5000kr</font id="red"> så är jag nöjd! Går affären smidigt bjussar jag på frakten!
03 Aug 2010, 14:47
