View unanswered posts | View active topics It is currently 17 May 2026, 14:39
Fulltone Fat boost - borta
Post Fulltone Fat boost - borta
Fulltone Fat boost, model FB-3 ,
Quote:
Klass A clean boost med upp till 35 dB förstärkning med FET transister för bruseliminering.
Quote:
The Fulltone FatBoost 3 is a discrete, Class-A, FET (Field-Effect-Transistor) guitar pedal offering up to 35dB of non-distorted gain without changing your signature sound, unless you want that. You can fatten/distort your tone, brighten or mellow up the sound, add or subtract bass, and even add harmonics. The FB-3 has true-bypass switching (via the Fulltone 3PDT) and incorporates a super-bright LED without the loud popping sound thanks to Fulltone's proprietary anti-pop circuitry.
FET's can behave like tubes in a properly designed circuit. They can clip (distort) in a pleasing way instead of being buzzy or spiky-sounding (like a transistor) and can also add a subtle limiting to the signal which can even out the volume making your live and recorded tones more pleasing to the ear.
"I'm gonna put a curse on you and all your kids will be born completely naked. " J.Hendrix
28 May 2017, 14:27
Post Re: Fulltone Fat boost
Byte???Har en Digitech Hardwire SC-2 made in usa + en symbolisk hundring till dej!!!
//Robban
GREEN KRYPTONITE
ROB`S ROCKIN`BLUES COMBO
02 Jun 2017, 14:25
Pm. Igen.
John Kee
04 Jun 2017, 10:21
