View unanswered posts | View active topics It is currently 07 May 2026, 06:57
Lovepedal Eternity Kanji Handwired :: Intressekoll
Post Lovepedal Eternity Kanji Handwired :: Intressekoll
1500:- eller lägg bud.
Bild kanske möjligtvis eventuellt kommer.
Kopierar lite gammal text från Lovepedal hemsida.
The sound: this pedal is amazing, straight up. Firstly, it’s not completely transparent; it adds a slightly mid-humped, very warm character to your tone. I stress, very warm. The Kanji is probably best described as a low to medium gain overdrive; however, cranked up in front of a tube amp, this thing has gigantic balls, so you might even find yourself backing off on the Drive a bit. I usually tweak starting with the Level knob, as I believe it has the most influence over your tone, and then adjust the Drive and Glass to fine-tune the sound once I find it.
The Kanji gives you anything from a gigantic warm clean boost, to creamy sustain on the neck pickup that goes on for days, to edgy classic rock tones. Although, as stated above, this pedal needs a bit of tweakage, but once you learn how to control the pedal, you can coax a lot of different sounds out of it. This is a very versatile Overdrive pedal.
Last bumped by melander on 17 Nov 2019, 14:50.
17 Nov 2019, 14:50
