View unanswered posts | View active topics It is currently 02 May 2026, 02:32
Skreddy Screw Driver. Sunn Model T Preamp In A Box.
Post Skreddy Screw Driver. Sunn Model T Preamp In A Box.
Skreddy. Sunn Model T AIB
SKREDDY SCREWDRIVER MINI DELUXE
Extremt touch sensitive pedal i nyskick (kardborrband på undersidan). Täcker allt från amp-like boost till fuzzy overdrive.
2.200 kr inklusive frakt.
Discontinued and rare! En eftertraktad klassiker.
Versatile low, medium, or high- gain overdrive
Skreddy Pedals? Screw Driver is the perfect marriage of sparkle, grit, and growl. Featuring a detailed, cutting twang & jangle and at the same time a smooth, thick, touch-sensitive, mellow response, you will be amazed at the beautiful tones you will hear coming out of your amp. Just the right amount of compression and a wonderfully biting attack along with a sweet, singing quality on leads. Chords, arpeggios, double stops, single notes; everything cuts through and sits perfectly in a band mix.
You will hear familiar shades of Stones, Zeppelin, Floyd, Hendrix, SRV, Trower, Skynyrd, and REM; and you will definitely find your own unique voice loud and clear.
This pedal is so classic rock and yet so versatile and modern, it promises to do away with every other general-purpose overdrive on your pedal-board.
Incidentally, you will probably find that the Screw Driver? has more output volume than you need, but it's there in case you love to push your amp!
Features 9v battery clip (no battery included), DC adapter jack, blue LED on/off indicator, and of course true bypass switching.
A synthesis of clean boost, overdrive, and distortion
One of the most touch-sensitive pedals ever, this unique Skreddy Pedals design features a mosfet treble-boost input stage followed by a highly modified, tightly-controlled, hybrid fuzz circuit. (The term "hybrid fuzz" refers to a silicon transistor driving a germanium transistor)
Every aspect of the Screw Driver? has been optimized for maximum versatility, lush and controllable vintage 'dirt' voicing, noiseless performance, and ideal tonal balance.
Inspire yourself!
Controls: Volume, Gain, Sharpness, Brilliance and Pre-Gain. bullet
The Sharpness control dials in the amount of bass going into the distortion section, for everything from thin, twangy treble-boost to midrange grit to thick, fuzzy breakup. bullet
Gain controls the tamed-down hybrid fuzz section (old-school silicon into germanium) and takes you from slightly gritty clean through touch-sensitive overdrive all the way to aggressive distortion. bullet
The Brilliance control lets you get a lot more brilliance and bite or make it darker and smoother, to suit your amp and taste. bullet
The Pre-Gain control sets the gain of the mosfet input stage. I added this control to let users of humbuckers and other higher-output guitars get the same clean-up ability as single-coil users, but anybody who likes their overdrive to be clear and bell-like will love this feature! You can go all the way to a rich-sounding clean boost with full, meaty bass frequencies undistorted (if you also turn down the Sharpness and Gain) OR, you can dial in a more aggressive, modern, compressed tone by turning up the Pre-Gain control.
CODA BLACK HOLE
Sunn ModelT 2-kanals pre-amp. Amp In A Box.
Grym pedal i absolut nyskick. Emulerar en klassisk förstärkare på ett naturligt sätt. Mycket Doom och Stoner, men funkar bra för all tyngre rock.
1.800 kr inklusive frakt eller bästa bud.
The Coda Effects Black Hole is my version of the almighty Sunn Model T preamp. The Sunn Model T is a 150W amp from the sixties, known for its monstruous tone: lots of bass, heavy distortion.
It is used a lot in the doom / stoner scene. There is even a band named after it, the almighty Sunn o))) band. Put a Rat before this and be ready to spit antimatter doom riffs!
Here are the controls:
Dual channels gain controls: the two channels (Normal and Brite) can be mixed in parallel for a more heavy sound.
Three band EQ control, to sculpt your sound at will
Boost switch to unleash mayhem
Optimized for guitar and bass
The Black Hole is made with the best components available (Wima and Panasonic capacitors, Fairfield semiconductors, Amphenol jacks...). I make them in Paris, France with great care and patience.
CARACTERISTICS
True Bypass: I use Alpha 3PDT switch for more durability and reliability
Power: standard 9V DC, less than 50mA, center negative to make the Black Hole compatible with pedalboard use.
Size: 12,1 cm / 4,76" (L) x 6.6 cm / 2,6" (W) x 3.5 cm / 1,38" (H)
Weight: 312,9g / 11,03 oz
24 Mar 2020, 18:37
