View unanswered posts | View active topics It is currently 12 May 2026, 13:01
Reply to topic  [ 15 posts ]
Radial Tonebone Classic Distortion *Bortbytt*
Post Radial Tonebone Classic Distortion *Bortbytt*
BORTBYTT
Sista chansen. Till helgen byter jag annars bort denna...
Radial Tonebone Classic Tube Distortion (Blå), 950kr.
(Kostar 2280kr + frakt ny hos tysken.)
Prisbelönad distpedal, flera gånger om.
Används bl.a. av Gary Moore, Steve Lukather och Eric Johnson
Inklusive 15V (1000mA) strömadapter (230V/50Hz) i nyskick (ej original). Modell HQ Power PS1510. Korrekt volt och tillräcklig ampere för att klara belastningen med lätthet. Adaptern är även skyddad mot övertemperatur och kortslutning. 1.85 meter lång kabel. (bild längre ned)
Kanonpedal, speciellt med boost.
Inte riktigt mitt ljud, därför släpper jag den.
Begagnad men i jättefint skick. Allt komplett med kartong och garanterat helt fungerande. Kardborre under både pedal och strömadapter.
Finns i Uppsala.
Kan skickas.
Tillverkarens info:
http://tonebone.com/tb-classic.htm
Quote:
12AX7 tube for natural overdrive tone
True bypass clean mode
Powerful EQ for wide tonal range
Ultra low-noise - amazing dynamics and feel
Cleans up like a tube amp when guitar turned down
The Tonebone Classic is a 12AX7 tube equipped true-bypass distortion that has been optimized for flexibility and tonal range.
Following the vision set by Leo Fender in the 1950’s, the Classic is based on vintage overdrive sounds that started in the '60s and '70s and today remain some of the most sought after tones. With three drive settings, variable drive control and powerful EQ, the Classic lets you dial in the slight overdrive to high-gain saturation and everything in between.
And like a real tube amp, when you turn your guitar volume down, the Classic cleans up naturally - without the noise, hum or buzz that is common with most other pedals. At higher settings, every note remains distinct. The Classic is so responsive and dynamic your playing style shines through!
The Radial Tonebone Classic – the most dynamic and responsive distortion pedal ever!
03 Jan 2011, 08:43
bump
18 Jan 2011, 13:10
Prisbump! [:D]
26 Jan 2011, 08:26
Var finns den?
26 Jan 2011, 11:16
Finns i Uppsala!
Bump!
26 Mar 2011, 06:04
BUMP [:)]
09 Jul 2011, 23:36
Byten/delbyten beaktas också.
* Såsom t.ex. de flesta halv-hetare boutique pickups (typ Suhr Aldrich, Dimarzio 36th Anniversary, Motorcity Pickups, Bare Knuckle osv.)
* Letar efter Rio Grande Texas 50mm i Svart.
* Även pedaler är av intresse. T.ex. Flex Drive, det mesta AnalogMan eller Monte Allums, Dunlop EVH wah, MXR Phaser, Boss TU-2 eller TU-3, Turbo Tuner, MC401 Boost/Line Driver.
* Letar även efter en övningsstärk Blackstar HT-1 eller HT1-R.
* Hardcase till stratta eller les paul är också intressant.
16 Jul 2011, 16:38
BUMP för en bra pedal. [8D]
Kolla in detta klipp där Steve Lukather solar loss med ToneBone!
FETT sololjud!
http://youtu.be/48alL34q3qI?t=5m48s
25 Jul 2011, 06:54
BUMP!
08 Aug 2011, 19:41
bump
15 Aug 2011, 00:45
En sista BUMP!
OBS! Sista chansen att köpa denna av mig.
Kommer annars bytas bort i helgen.
17 Aug 2011, 18:03
Monte Allums moddad Boss OD-3?
Senaste versionen av modden.
Pedalen i nyskick.
18 Aug 2011, 08:52
Tack för förslaget Rambler. Antingen säljs Tonebone'n eller byts den bort. Några på forumet har givit mig andra förslag att också fundera över. Jag måste tänka på saken. Du får svar i tråden under helgen hur jag gör.
19 Aug 2011, 06:38
Tyvärr Rambler. Nu är Tonebone'n bortbytt till biffen här på forumet. Tack ändå för ditt förslag. Vi kanske kan byta nått annat framöver.
20 Aug 2011, 20:58
Tjena Daniel!
Det verkar som att inte mina mail kommer fram till dig. Jag får dina mail iaf.
Jag har postat dom två pedalerna till dig idag!
22 Aug 2011, 16:55
